Tony-Orbi
Jul 01, 2020Aspirant
Orbi RBR50 - adding an additional router with a different IP address
I am in the process of adding a small router to run my IoT devices separate from the Orbi wi-fi for security purposes. I have the following configuration. My Ip addresses are 192.168.1.x for the Orbi,...
Jul 01, 2020Guru - Experienced User
Why not put the 4.x router behind the FIOS gateway instead of the orbi router. Why do you not want the 4.x devices to see the 1.x devices?
- Tony-OrbiJul 02, 2020Aspirant
Hi FURRYe38, my small router has only a single ethernet port so I would not be able to put the Orbi behind it, I would have to connect it directly to the FIOS Gateway. This is not secure. As for why I do not want the 4.x to see the 1.x it is becasu they are going to be IoT devices and they are not secure. If I get hacked on the 4.x all they will see will be the IoT and not my computers.
Tony.
