goblea
Mar 05, 2020Star
Orbi RBR50 - Backhaul status disconnected
I am having major issues with my Orbi system, I have the RBR50 in AP mode with a static IP along with 3 RBS50's as I have these at each TV location to give me cabled connections to my devices, the sa...
theoak
Mar 05, 2020Luminary
Try down grading your firmware to 2.3.5.30. The GUI seems to be more accurate with that version.
I experienced essentially the same thing that you did with 2.5.1.8.
- FURRYe38Mar 06, 2020Guru - Experienced User
Hopefully won't have to downgrade...seem more like too much wifi going on in a small home. Hopefully the RBR and jsut 1 RBS will be able to work better...Hope they respond back.
theoak wrote:Try down grading your firmware to 2.3.5.30. The GUI seems to be more accurate with that version.
