goblea
Mar 05, 2020Star
Orbi RBR50 - Backhaul status disconnected
I am having major issues with my Orbi system, I have the RBR50 in AP mode with a static IP along with 3 RBS50's as I have these at each TV location to give me cabled connections to my devices, the sa...
Mar 29, 2020Guru - Experienced User
RBR and RBS should be on the same version of FW.
After updating FW to v2.5.1.8, be sure to factory reset the RBS and RBR and setup from scratch. I would walk the setup wizard and skip adding the RBS during the wizard process. Once the wizard completes, add 1 RBS wirelessy to the RBR wile having them in the same room as the RBR. Add them one at a time while checking the back haul status with a PC and web browser opened to the RBRs web page. Once they are added and you see the back haul. Power them off and place back in remote locations.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Loccs26
Mar 29, 2020Aspirant
Yes they are on the same version of firmware. However the downloads have different names. For example:
RBS50-V2.3.5.30
RBR50-V2.3.5.30
There is no reason to factory reset the devices when the older version of the firmware takes and the backhaul status appears. It is a bug in the new firmware.
- FURRYe38Mar 29, 2020Guru - Experienced User
Something I haven't seen with v2.5.1.8 loaded. Others as well. A reset is needed if the status isn't working for you after upgrading FW.
If you have v30 loaded then keep it loaded.
- Loccs26Mar 29, 2020Aspirant
I will, just learned that from the upgrade fiasco.
If you feel the FW isn't working for you, please file a support ticket here:
https://www.netgear.com/support/#
Enjoy.
