goblea
Mar 05, 2020Star
Orbi RBR50 - Backhaul status disconnected
I am having major issues with my Orbi system, I have the RBR50 in AP mode with a static IP along with 3 RBS50's as I have these at each TV location to give me cabled connections to my devices, the sa...
Atreides
Apr 11, 2020Tutor
New firmware messed up my system exactly as people here have stated. A full factory reset of my router and 2 satelittes have returned the Backhaul status to good but my devices are still hidden. This is insane that we would have to reset everything and still there is issues. I may have to downgrade the firmware but I would like to stay up to date.
What is Netgear doing?!
Apr 12, 2020Guru - Experienced User
You can rollback to a previous version by re-installing your previous version over the current version. All supported RBK50 firmware versions can be downloaded from here.
To (re)install firmware, head over to ADVANCED Firmware Update page and select the Manual Update. Then upload the firmware version you want to install. Repeate the same steps for all the Satellites. To access the Satellite UI, points your browser at its IP address.
Users are encouraged to file a support ticket here to let NG know what your seeing:
https://www.netgear.com/support/#
Good luck!
Atreides wrote:New firmware messed up my system exactly as people here have stated. A full factory reset of my router and 2 satelittes have returned the Backhaul status to good but my devices are still hidden. This is insane that we would have to reset everything and still there is issues. I may have to downgrade the firmware but I would like to stay up to date.
