kaizer_zoze
Feb 26, 2022Initiate
Orbi RBR50 - blocking websites
Hi. My Orbi is blocking access to some websites (eg Google) and some banking apps. I tried mobile (cellular) network and other wifi networks and this does not occurs. Any ideas what could it ...
Feb 27, 2022Guru - Experienced User
1. what firmware is on the orbi?
2. what modem/gateway is the orbi connected to?
3. what actual error does it give?
4. is ipv6 enabled?
5. have you tried a different dns provider? You can try googles at 8.8.8.8 or 8.8.4.4
kaizer_zoze
Feb 27, 2022Initiate
Hi Plemans
Thank for your response. It appears that the issue is Disney Circle blocking this sites. The orbi has the latest firmware
Not sure what’s going on. As mentioned, nothing has changed in terms of setup.
Any ideas? I realised they this may not be the right forum for this question now.
- plemansFeb 27, 2022Guru - Experienced User
If you're using disney circle, there should be a filter list that you can modify
- FURRYe38Mar 06, 2022Guru - Experienced User
Are you using Armor or Disney?
@david1234es wrote:
I am facing the same issue when trying to access the website. I am using an Orbi system that has been working well for years. Router FW is V2.7.3.22, and nothing shows as available to upgrade.
