kaizer_zoze
Feb 26, 2022Initiate
Orbi RBR50 - blocking websites
Hi. My Orbi is blocking access to some websites (eg Google) and some banking apps. I tried mobile (cellular) network and other wifi networks and this does not occurs. Any ideas what could it ...
kaizer_zoze
Feb 27, 2022Initiate
Hi Plemans
Thank for your response. It appears that the issue is Disney Circle blocking this sites. The orbi has the latest firmware
Not sure what’s going on. As mentioned, nothing has changed in terms of setup.
Any ideas? I realised they this may not be the right forum for this question now.
Feb 27, 2022Guru - Experienced User
If you're using disney circle, there should be a filter list that you can modify
