Christopher1020
May 09, 2020Aspirant
Orbi RBR50 - Cannot Connect August Connect Module
Just bought a Yale smart lock with an August Connect module. Been trying for days to connect the August Connect to my Orbi Wifi with the August technical support. They finally told me that they can...
Christopher1020
Yes, connecting with the August App and it's probably crappy. The device has to connect at 2.4. Just now, I disabled the SSID broadcast for 5.0 and confrmed the phone was connected to 2.4 Ghz. Still didn't connect. Tried disabling the daiseychaining as well and that didn't do anything. Is there a way to connect the device without the app?
michaelkenward
May 09, 2020Guru - Experienced User
Who knows? Ask the people who made the device. Netgear isn't likely to know all about every wonky IoT device out there.
Sometimes a search around here for the device will find something useful.
