Christopher1020
May 09, 2020Aspirant
Orbi RBR50 - Cannot Connect August Connect Module
Just bought a Yale smart lock with an August Connect module. Been trying for days to connect the August Connect to my Orbi Wifi with the August technical support. They finally told me that they can...
Christopher1020
May 10, 2020Aspirant
Are you running all the Orbi wifi defaults other than simple changes like channel or security?
A: pretty much. I tried changing the 2.4GHz from auto to channel 6
- Have you changed CTS/RTS Threshold in Advanced...Advanced Wireless Settings to 2347? Yes, this is set to 2347
- If you disable AX in Advanced...Advanced Wireless Settings does it help? I'll give it a try.
Thanks
Mikey94025
May 10, 2020Hero
Oops, sorry I forgot you have the RBR50 and not the AX product. Ignore this -- You don't have this option. :-)
