Christopher1020
May 08, 2020Aspirant
Orbi RBR50 - Cannot Connect August Connect Module
Just bought a Yale smart lock with an August Connect module. Been trying for days to connect the August Connect to my Orbi Wifi with the August technical support. They finally told me that they can...
Christopher1020
May 10, 2020Aspirant
All, I finally connected. My son came home and I borrowed his iPhone again. All settings were back to normal on the Orbi. One try, and it connected. Seems the August app has a problem with the Android.
Although I did try the setup with the iPhone before, I think for some reason Orbi blocked it then. This time I had Orbi app open to see it, but I didn't have to do anything. It connected. Thanks for the Help!
