sit1975
Aug 05, 2021Follower
Orbi RBR50 - changing to a new Cable Modem/Router device
Hi - I am in the UK and am a Virgin Media customer with 150MB speed - they gave me their Smart Hub 3.0 which is now at least 4 years old and for this time I have been using an ORbi RBR50 connected to...
Aug 05, 2021Guru - Experienced User
Might ask the ISP what is and is not supported on there network first and see what is available. Recommended would be a modem ONLY unit and keep the RBR50 and any satellites running as that system is working well for you. Then at some point, you could get into Orbi AX system if you have a desire too. I'ts recommended to use modems and routers separately for ease of maintenance and troubleshooting.
