FirePups
Dec 29, 2017Follower
Orbi RBR50 - connection and won't recognize passwords
I have an Orbi RBR50 and satellite that I bought in April of this year. The set-up was easy and everything went fine. I moved and set the router up first and it was fine until yesterday when I went t...
DarrenM
Jan 02, 2018Sr. NETGEAR Moderator
Hello FIrepups
You may need to factory reset the unit by holding the reset button for 10+ seconds then you should be able to use the default login admin/password.
DarrenM
