Mardi
Apr 01, 2019Initiate
Orbi RBR50 - Constant dropping when streaming to Roku - Can't update firmware! HELP!
My Orbi started dropping my signal every few minutes for streaming. I am ok on my computer. Here is my configuration RBR50 Firmware: 2.2.1.210 Windows 10. My Orbi is set to autoupdate firmware, but i...
Apr 01, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Mardi wrote:
My Orbi started dropping my signal every few minutes for streaming. I am ok on my computer. Here is my configuration RBR50 Firmware: 2.2.1.210 Windows 10. My Orbi is set to autoupdate firmware, but it is not doing it. I don't know what is going on. I tried reading the other postings, but nothing matched what is going on with my system. I have a Roku 3 that I use to stream.
I would appreciate any help you can give me. I'm really frustrated with this -- I don't know what to do.
Thank you!
