keithv's avatar
keithv
Follower
Jun 06, 2018
Orbi RBR50 - F/W: 2.1.4.10 - Router Continuously Attempts to Seek Netgear Updates
I have a RBR50 Orbi router with a satelitte running my home network.  I use an internet modem for my internet connection - which connects into the internet port of the RBR50.  This configuration allows all my devices to have internet access.
That said, I've been chasing a data consumption problem.  I've reduced the problem so that the only devices left connected to the Orbi router is the internet hotspot.  Even still it consumes about a gigabyte of data an hour.  After running a wireshark capture between the mobile hotspot and the RBR50 router, i have determined that over 80% of the traffic is coming from http.fw.updates1.netgear.com. Inside of 10 minutes, it had downloaded approximately 160 MB of data.  Since June 1st, my router has consumed upwards of 20GB - this is a 5 day stretch.
It appears as though the router is in some kind of continuous loop trying to get firmware information/data from NetGear.  As a result of this isusue, I am unable to use the router any more and have reverted to an old unit so I do not blow my data usage caps for the month.
Any help would be appreciated as i would really like to put this Orbi product back into operation.
