Rick07
Aug 12, 2020Tutor
ORBI RBR50 - Hardware issue or bricked?
Hi, A first post, so thank you for any help. ORBI RBR50 suddenly stopped working a few days ago after 9 months of problem-free wireless internet. No power surges or brown-outs, no tinkering with an...
Mstrbig
Aug 12, 2020Master
Turn off the Orbi router, press and hold the reset button, turn on the Orbi router, while still pressing the reset button. What happens?
- Rick07Aug 13, 2020Tutor
Thanks Mstrbig
Gave it a try.
It boots in the usual way. Green LED on for 30secs. Short burst of Red flashing LED then Green again.
If I continue to hold the reset button for a further 30secs, 3 Red flashes then back to Green with white flashing top LED.
Still no wireless or wired connection..
- MstrbigAug 13, 2020MasterOnce it gets to that point, you have to now set it up using the app. The lights on top should blink white, until it is fully setup, which the will tell you
