Rick07
Aug 12, 2020Tutor
ORBI RBR50 - Hardware issue or bricked?
Hi, A first post, so thank you for any help. ORBI RBR50 suddenly stopped working a few days ago after 9 months of problem-free wireless internet. No power surges or brown-outs, no tinkering with an...
Rick07
Aug 13, 2020Tutor
Thanks Mstrbig
Gave it a try.
It boots in the usual way. Green LED on for 30secs. Short burst of Red flashing LED then Green again.
If I continue to hold the reset button for a further 30secs, 3 Red flashes then back to Green with white flashing top LED.
Still no wireless or wired connection..
Mstrbig
Aug 13, 2020Master
Once it gets to that point, you have to now set it up using the app. The lights on top should blink white, until it is fully setup, which the will tell you
- Rick07Aug 13, 2020Tutor
Mstrbig wrote:
Once it gets to that point, you have to now set it up using the appI cannot use the app as there is no wireless (or wired) network available to connect to.
Or have I missed something?- MstrbigAug 13, 2020Master
Rick07 wrote:
Or have I missed something?Have you tried running the app? Do you see the orbi's wireless SSID on your phone and can you connect to it? If you see it, connect to it, then run your orbi app and install the router.
