Profax
May 31, 2020Aspirant
ORBI RBR50 - Impossible to reset after power failure
Hi,
After a power failure at home, I lost the access to my orbi router.
I reboot both equipments the one after the other as described in ORBI documentation, connect with an ethernet cable to my ISP modem, try to ping the router, but still no access...
Note : When I power it on, I didn't had any light on top of it (blue, green and so). I still can see the green light at the back of the router which means that I got power.
Since I cannot access it anymore, I tried to reset it by holding the reset button at the back, but even after 1 minute, I still don't have any blinking orange led...
Do you think it's dead or do you see anything else I can try.
Thanks for your help!
CLement
Try both Windows TFTP or the downloadable TFTP program:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
- ProfaxAspirant
Thanks for your reply. That's what I did last time it happened (not the first time actually).
But this time my computer do not even recognize there is an Ethernet cable plugged in my Orbit :)
Try this method:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
Profax wrote:Thanks for your reply. That's what I did last time it happened (not the first time actually).
