ATeamAdam
Mar 23, 2020Guide
Orbi RBR50 - instability issues
My kids have been complaining about our wifi for 2 years. Now that I'm working from home I'm feeling their pain. I've rebooted my router probably a dozen times in the last week. Purchased Octob...
- Mar 24, 2020
Thanks for the quick insight. Appreciate the guidance.
Any Wifi Neighbors near by? If so, how many? I do have a few wifi neighbors, depending on where you are in the house you can see about a half dozen signals, most of them are pretty weak.
I setup these settings after the factory reset. Hopefully it goes smooth.
New config:
2.4 Ghz Channel - 6
5 Ghz Channel - 48
Beamforming - enabled
MIMO - enabled
WMM - enabled
Armor - disabled
Circle - disabled
Daisychain - disabled
Fast Roaming - disabled
IPv6 - disabled
20/40 mhz coexistence - disabled
Short preable - enabled
CrimpOn
Mar 23, 2020Guru - Experienced User
ATeamAdam wrote:Is my router dying?
Probably not, but it might be "sick". There seem to be two "camps" of Orbi users who have updated firmware to 2.5.1.8
- For some of us, it "works great". Same as always.
- For others, it is a "living nightmare" of issues such as you describe. There are very long posts about 2.5.1.8 that you can read through.
So, yes, a "Factory Reset" is one possibility. Save the configuration to your computer. (On the Advanced Tab, Administration, Backup Settings. Do the Factory Reset: https://www.youtube.com/watch?v=cMw4ePACgc4 When it comes up and is ready to configure, say that you want to "Reload a previous configuration". This is a relatively painless reset method.
If the issue persists, then it may be necessary to reconfigure the Orbi, which for me is over an hour of drudgery because I have made so many setting and assignments.
If the issue still persists, some people download firmware 2.3.5.30 from the Netscape support web site and do a Manual Firmware update (actually "down-date").
Sorry not to have better news.
MichaelCaz
Apr 27, 2020Aspirant
How did you get to the Netscape support web and complete the "down-date" of your system?
