ATeamAdam
Mar 23, 2020Guide
Orbi RBR50 - instability issues
My kids have been complaining about our wifi for 2 years. Now that I'm working from home I'm feeling their pain. I've rebooted my router probably a dozen times in the last week. Purchased Octob...
- Mar 24, 2020
Thanks for the quick insight. Appreciate the guidance.
Any Wifi Neighbors near by? If so, how many? I do have a few wifi neighbors, depending on where you are in the house you can see about a half dozen signals, most of them are pretty weak.
I setup these settings after the factory reset. Hopefully it goes smooth.
New config:
2.4 Ghz Channel - 6
5 Ghz Channel - 48
Beamforming - enabled
MIMO - enabled
WMM - enabled
Armor - disabled
Circle - disabled
Daisychain - disabled
Fast Roaming - disabled
IPv6 - disabled
20/40 mhz coexistence - disabled
Short preable - enabled
MichaelCaz
Apr 27, 2020Aspirant
How did you get to the Netscape support web and complete the "down-date" of your system?
ATeamAdam
Apr 27, 2020Guide
Instructions:
Router Firmware:
https://www.netgear.com/support/product/RBR50.aspx#download
Satellite Firmware:
https://www.netgear.com/support/product/RBS50.aspx#download
Keep in mind my links are only for the RBR50 router, and the RBS50 satellites. Your models may be different.
