sawall
Jul 10, 2018Aspirant
Orbi RBR50 - Internet status says Not Connected
I have an Orbi RBR50 (and a satellite). Looking at the status for the Internet, it says "Not Connected" (see image). But for the PC hardwired, it works, and wireless works - most of the time. I ca...
Jul 11, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem, firewall and this switch?
I would test the router directly connected to the firewall bypassing the switch as a quick test...
- sawallJul 11, 2018Aspirant
I can try to connect the Orbi directly to the ISP modem and see if that matters / changes. It's from Spectrum (aka Charter), but I don't know the model. The firewall / switch is a Palo Alto.
- FURRYe38Jul 11, 2018Guru - Experienced User
Do you know if the ISP modem is a modem only or does it have a built in router?
I think it is a modem only. It passes the Internet IP directly to my firewall. But I would need to confirm. I will have to look up the model and I'm not able to do so at the moment.
