AdamGH
Oct 07, 2018Guide
Orbi RBR50 - iPhone App Store/ESPN not working
Just set up my system and everything works great. WiFi has been extended throughout entire house. I have found two small issues. - my App Store will not download new apps or update apps - my ESPN ...
- Oct 22, 2018
Found the fix....
If you just access...
from a device that is connected to the orbi you will get a popup message saying "fixing your DNS because of a conflict with your provider.
After this it seems it is all working.
I think what they added to the webpage was automating the steps from this post:
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
ekhalil
Oct 08, 2018Master
Looks like a bandwidth/throughput issue. How much speed can you get from your iPhone when connected to Orbi?
AdamGH
Oct 08, 2018Guide
I have plenty of speed. 57 Mbps down and 61 Mbps up.
- ekhalilOct 08, 2018Master
Can be an issue in the iPhone network settings, can result from keeping the same SSID after changing the router. Try to reset your iPhone network settings:
Open Settings > Tap General > Tap Reset > Tap Reset Network Settings
If you're prompted to enter a passcode, enter it now then follow the onscreen instructions.
