AdamGH
Oct 07, 2018Guide
Orbi RBR50 - iPhone App Store/ESPN not working
Just set up my system and everything works great. WiFi has been extended throughout entire house. I have found two small issues. - my App Store will not download new apps or update apps - my ESPN ...
- Oct 22, 2018
Found the fix....
If you just access...
from a device that is connected to the orbi you will get a popup message saying "fixing your DNS because of a conflict with your provider.
After this it seems it is all working.
I think what they added to the webpage was automating the steps from this post:
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
AdamGH
Oct 08, 2018Guide
I have plenty of speed. 57 Mbps down and 61 Mbps up.
ekhalil
Oct 08, 2018Master
Can be an issue in the iPhone network settings, can result from keeping the same SSID after changing the router. Try to reset your iPhone network settings:
Open Settings > Tap General > Tap Reset > Tap Reset Network Settings
If you're prompted to enter a passcode, enter it now then follow the onscreen instructions.
