AdamGH
Oct 08, 2018Guide
Orbi RBR50 - iPhone App Store/ESPN not working
Just set up my system and everything works great. WiFi has been extended throughout entire house. I have found two small issues. - my App Store will not download new apps or update apps - my ESPN ...
- Oct 23, 2018
Found the fix....
If you just access...
from a device that is connected to the orbi you will get a popup message saying "fixing your DNS because of a conflict with your provider.
After this it seems it is all working.
I think what they added to the webpage was automating the steps from this post:
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
ekhalil
Oct 08, 2018Master
Can be an issue in the iPhone network settings, can result from keeping the same SSID after changing the router. Try to reset your iPhone network settings:
Open Settings > Tap General > Tap Reset > Tap Reset Network Settings
If you're prompted to enter a passcode, enter it now then follow the onscreen instructions.
AdamGH
Oct 08, 2018Guide
Just reset my network settings. Did not work. Still having problems. Any other ideas?
- ekhalilOct 09, 2018Master
Have you tried with other iPhones connected to the Orbi? Can it be a phone issue?
- AdamGHOct 09, 2018GuideYes. Same issue on my brother’s phone and wife’s phone too.
- MRMikeROct 09, 2018Initiate
I also have this issue. I did not reuse my old SSID, I have rebooted everything, reset network settings, etc. I cannot update my iphone's apps, and there are a few financial apps that will not run. Everything else on it runs fine. Same on my ipad, and my daughter's fire tablet. Sony playstation also has difficulty.
I have a ton of speed, and other devices are all working as intended.
