AdamGH
Oct 08, 2018Guide
Orbi RBR50 - iPhone App Store/ESPN not working
Just set up my system and everything works great. WiFi has been extended throughout entire house. I have found two small issues. - my App Store will not download new apps or update apps - my ESPN ...
- Oct 23, 2018
Found the fix....
If you just access...
from a device that is connected to the orbi you will get a popup message saying "fixing your DNS because of a conflict with your provider.
After this it seems it is all working.
I think what they added to the webpage was automating the steps from this post:
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
NewOrbiNow
Oct 23, 2018Tutor
I tried this with my wifes iphone which is a different version and all the same problems are there... cannot download apps... cannot use ESPN app. Cannot use the other apps.
DNS fix that was linked does not resolve the issue.
I called a buddy who recommended the orbi and asked him to try and he said the same problem occurs for him... so this is occuring for everyone.
Does anyone have a fix for this? Don't want all this stuff not working.
AdamGH
Oct 23, 2018Guide
Yeah. I am the original poster and have unfortunately given up. I am using my old wireless right now because every iPhone is having the same issue. My brother and his friends were over and all had the same issue. It is a real problem. Wish I had the answer.
