AdamGH
Oct 08, 2018Guide
Orbi RBR50 - iPhone App Store/ESPN not working
Just set up my system and everything works great. WiFi has been extended throughout entire house. I have found two small issues. - my App Store will not download new apps or update apps - my ESPN ...
- Oct 23, 2018
Found the fix....
If you just access...
from a device that is connected to the orbi you will get a popup message saying "fixing your DNS because of a conflict with your provider.
After this it seems it is all working.
I think what they added to the webpage was automating the steps from this post:
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
NewOrbiNow
Oct 23, 2018Tutor
Found the fix....
NewOrbiNow
Oct 23, 2018Tutor
Hmmm... checked my AP Mode/Router Mode setting and I was still in Router mode and everything was working fine after accessing the site... so you can ignore the link to netgear I posted and just access the http://orbilogin.com site from inside the orbi wifi and it should work.
Just as an FYI I tried AP mode and it did not seem to do anything. Speeds were exactly the same and everything still worked in AP mode.
