danassef
Jul 09, 2022Follower
Orbi RBR50 - No internet connection
I have an Orbi RBR50 router with 4 satellites connected to it. On my network map in the Orbi app it shows my router connected to my internet with the 4 satellites connected to the router. All are gree...
Jul 09, 2022Guru - Experienced User
What modem/gateway are you connected to?
That's usually referring to the connect from modem/gateway to the router is having issues.
