Stefano33333333
Oct 09, 2020Follower
ORBI RBR50 - one satellite does not connect
I have a ORBI RBR50 (router + 2 satellites), one for each floor. Router is in middle floor. connection with satellite in top floor is ok. connection with satellite in bottom floor is a no-go. How ...
Mstrbig
Oct 09, 2020Master
Stefano33333333 wrote:I have a ORBI RBR50 (router + 2 satellites), one for each floor. Router is in middle floor. connection with satellite in top floor is ok.
How can I have the connection with this satellite working?
I have in the bottom floor a cabled connection (via ORBI router). Can I enter in the satellite with a cable, and then spread wi-fi through the satellite? I have tried, but did not suceed.
or otherwise?
Stefano
Turn off DaisyChaining and see if it makes a difference. Yes you can connect the satellite with a cable, through the satellite, and then spread wi-fi, as long as it is connected to the Orbi router. The satellite has to be configured first, then move it anad plug it in.
