Stefano33333333
Oct 09, 2020Follower
ORBI RBR50 - one satellite does not connect
I have a ORBI RBR50 (router + 2 satellites), one for each floor. Router is in middle floor. connection with satellite in top floor is ok. connection with satellite in bottom floor is a no-go. How ...
Oct 09, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Stefano33333333 wrote:I have a ORBI RBR50 (router + 2 satellites), one for each floor. Router is in middle floor. connection with satellite in top floor is ok.
How can I have the connection with this satellite working?
I have in the bottom floor a cabled connection (via ORBI router). Can I enter in the satellite with a cable, and then spread wi-fi through the satellite? I have tried, but did not suceed.
or otherwise?
Stefano
