JustinDS89
Jan 11, 2018Aspirant
Orbi RBR50 - Port Forwarding Not Working
I have an Emby media server set up which works great locally, but does not work remotely. I have the neccessary ports forwarded in Orbi, but it doesn't work at all. I have checked with various po...
CSK401
Jan 15, 2018Aspirant
You don't say which ports or protocol you are tring to open; I have opened both ports 80 & 8080 for HTTP for some webcams; this has worked perfectly on two different routers. I did run into some proceedural issues; such as I had to open 8080 first for the first internal IP; edit the name to something other than HTTP; then go back and open port 80 for the other internal IP. Then you MUST reboot the server for the changes to take effect. hope that is of some assistance.
