Grinch777
Nov 23, 2020Aspirant
Orbi RBR50 - Ring Door Bell Compatibility?
When I first purchased and installed the Orbi RBR50 and sattelite a year ago I had a problem connecting the Ring Doorbell 2nd gen. I was informed at the time that for some reason (never discovered w...
CrimpOn
Nov 23, 2020Guru - Experienced User
Grinch777 wrote:When Ring introduced the 2.4 & 5.00mhz 3rd generation doorbell I upgraded and to my annoyance although I find that although the 3rd gen the door bell now reconises the Orbi network it will still not connect,
Can you explain a little more about "recognises the Orbi network" and "not connect"?
- The doorbell setup procedure does not complete?
- The doorbell does not appear in the Orbi "Attached Devices" display?
- "Live View" does not work?
What country are you in?
