elrao
Feb 01, 2022Aspirant
Orbi RBR50 - Solid Magenta - Not connecting to Modem
Hi All I have a Zyxel modem setup in VDSL bridge mode, with an RBR30 as my router. I followed the instructions here: https://kitz.co.uk/routers/zyxel_VMG8324-B10A_bridge.htm to set this up and i...
Feb 01, 2022Guru - Experienced User
Check your ISP modem and ISP services up to the modem.
Power off both modem and RBR for 1 minute then back ON.
Turn off and unplug modem.
Turn on computers and rest of network.
- plemansFeb 02, 2022Guru - Experienced User
It wouldn't have been the first time an ISP supplied device got an update or change and caused conflict.
If the passthrough/modem only mode isn't working properly. Log into the router and change it to AP (access point) mode.
The ISP router needs to be in router mode so make sure to put it in that mode prior to changing the orbi.
- elraoFeb 09, 2022Aspirant
Hi
plemans , FURRYe38 thanks for your comments.
plemans The ISP supplied device was not connected when the error occured and so can't be the cause of the conflict. I had only re-connected the ISP supplied device in order to check if the problem was with the ISP or with my hardware. Not sure if the Zyxel would have done an OTA update.
I haven't tried setting up the Zyxel as the router, with the Orbi in AP mode. I assume that you can have the main ORBI (i.e. the router) in AP mode and have satellites with no issues? I guess I assumed I needed to use the ORBI as the router to make use of the mesh network.
FURRYe38 I have already done 95% of what you said. Using the ISP modem/router to validate the line is OK. I then disconnected it all and started again with my own Modem (the Zyxel) and powered this on (VDSL light goes orange to show connected), then powered on the Orbi (light goes Magenta after a few minutes).
The only thing I didn't do was turn off ALL devices connected to the network (there are about 50 if you include the WiFi ones); however I do have static IPs set for the majority of devices (none that would conflict with either the 192.168.1.1 assigned to the modem and 192.168.1.254 assigned to the ORBI).
- plemansFeb 09, 2022Guru - Experienced User
If the orbi is in access point mode, the mesh/roaming/satellites will all still function properly.
Its not typical to have the modem and the router in the same subnet (192.168.1.***) if they're in a proper passthrough/modem only/dmz mode. Thats why you can get conflicts.
You might have just been lucky or not had enough devices to cause conflicts.
so I'd try leaving the ISP gateway in router mode (disabe its wifi) and put the orbi in access point mode.
