Paolo85
Oct 23, 2019Follower
ORBI RBR50 - Speed issue through wireless connection
I have recently purchased a Orbi RBR50 (router + 1 satellite). When I test the internet speed at the router through the Orbi app I measure: download speed of 550mbps or above and upload of 900mbps or ...
Oct 23, 2019Guru - Experienced User
What devices are you using to speed test? Wired or wireless? Wired PC is preferred.
Try using Ooklas installable speed test app.
Speed test with a PC directly connectec to the RBR.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(
