ScottyJohn
Jul 29, 2021Aspirant
ORBI RBR50 - TCP & UDP Port opening
Hi, I've been trying to get the latency of Battlefield down on my PS4 and was told by EA Games that I needed to get the ISP to open the following ports: TCP: 3074 UDP: 88,500,3074,3544,4500 ...
ScottyJohn
Thanks for the reply.
It looks like UPnP is enabled (Screenshot attached). So is it better to delete PF rule or keep it and disable UPnP?
The ISP router that my Orbi is connected to is:
Huawei
EchoLife HG8240T
Do you have any suggestions on how I can improve the latency if this won't work?
Jul 29, 2021Guru - Experienced User
Your ISP ONT already has a built in router I believe. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode. uPnP could be enabled here and no PF configurations or vs versa...
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
