ScottyJohn
Jul 29, 2021Aspirant
ORBI RBR50 - TCP & UDP Port opening
Hi, I've been trying to get the latency of Battlefield down on my PS4 and was told by EA Games that I needed to get the ISP to open the following ports: TCP: 3074 UDP: 88,500,3074,3544,4500 ...
fannu1
Mar 12, 2023Tutor
It sounds like you may have configured your router correctly by opening the necessary ports, but there are a few other things you can try to improve your latency in Battlefield:
Make sure you have the latest firmware for your router. Check the manufacturer's website for any updates and follow the instructions for updating the firmware.
Connect your PS4 to the router with an Ethernet cable instead of using Wi-Fi. This can help reduce latency and improve your connection.
Disable any other devices on your network that may be using bandwidth, such as streaming services or downloads on other devices. This can help free up bandwidth for your PS4.
Check your network for any other potential sources of interference, such as other wireless networks or devices that may be causing interference. Try to move your router to a more central location in your home, away from other devices that may be causing interference.
Contact your ISP and ask if they have any suggestions for improving your latency. They may be able to provide additional support or offer other solutions.
I hope these tips help improve your latency in Battlefield!
