AaronLTek
Apr 06, 2020Guide
Orbi RBR50 - VERY SLOW client speeds
I've had this installed for a week or so and I'm seeing VERY SLOW, and VERY INCONSISTANT speeds even with line-of-sight and almost any distance. Please let me know if you've seen this problem, or kn...
theoak
Apr 07, 2020Luminary
Channel 9 for 2.4G seems odd. I would set it to channel 1; especially, if no one else is around you and/or far.
Is it just the router or is there a satellite floating around too? Try using just the router and see what you get.
You are also using an Android phone ... you should have gotten an iPhone :smileysurprised: Oh wait ... wrong forum :smileyembarrassed: (joking)
AaronLTek
Apr 07, 2020Guide
Hi All, thx for the help.
The system is a 100% fresh, brand new setup so not going to do a factory reset.
Speed problems are on 5Ghz where there is zero interference from other Wifi radios.
Across ALL APs... 24 devices connect to 5Ghz while only 5 devices connect to 2.4 so it doesn matter but for those asking, Channel is Auto, no clue why it showed (9) but here's what it shows now...
WIRELESS SETTINGS (GENERAL)
| Region | North America |
| 2.4G Channel | Auto ( 3 ) |
| 2.4G Mode | Up to 400 Mbps |
| 5G Channel | 36+40+44+48(P) |
| 5G Mode | Up to 866.7 Mbps |
- Retired_MemberApr 08, 2020
WAaronLTek wrote:Hi All, thx for the help.
WIRELESS SETTINGS (GENERAL)Region North America 2.4G Channel Auto ( 3 ) 2.4G Mode Up to 400 Mbps 5G Channel 36+40+44+48(P) 5G Mode Up to 866.7 Mbps What firmware did you end up with?
- FURRYe38Apr 08, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz.
WIRELESS SETTINGS (GENERAL)Region North America 2.4G Channel Auto ( 3 ) 2.4G Mode Up to 400 Mbps 5G Channel 36+40+44+48(P) 5G Mode Up to 866.7 Mbps - AaronLTekApr 10, 2020Guide
Problem seems is gone, I now get consistant connections (no dropped connections) and consistant speeds (351 where I was previously gett between 7 and 178, averaging 58). See all my current settings. I only changed 3, all the others were already the same.
I had rebooted all the routers a few times before I made the setting changes so it was def the settings... I'll assume buggy firmware.
1. disabled/unchecked 'Enable 20/40 MHz Coexistence' *** this is for 2.4Ghz radio and my problem was on 5Ghz radio
2. set Premable Mode to 'Short Preamble' *** maybe this? Still should have not mattered
3. enabled/checked 'Enable Fast Roaming' *** should have not mattered for as the issue was not about roaming, it was about speeds
