AaronLTek
Apr 06, 2020Guide
Orbi RBR50 - VERY SLOW client speeds
I've had this installed for a week or so and I'm seeing VERY SLOW, and VERY INCONSISTANT speeds even with line-of-sight and almost any distance. Please let me know if you've seen this problem, or kn...
AaronLTek
Apr 07, 2020Guide
Hi All, thx for the help.
The system is a 100% fresh, brand new setup so not going to do a factory reset.
Speed problems are on 5Ghz where there is zero interference from other Wifi radios.
Across ALL APs... 24 devices connect to 5Ghz while only 5 devices connect to 2.4 so it doesn matter but for those asking, Channel is Auto, no clue why it showed (9) but here's what it shows now...
WIRELESS SETTINGS (GENERAL)
| Region | North America |
| 2.4G Channel | Auto ( 3 ) |
| 2.4G Mode | Up to 400 Mbps |
| 5G Channel | 36+40+44+48(P) |
| 5G Mode | Up to 866.7 Mbps |
Retired_Member
Apr 08, 2020
WAaronLTek wrote:Hi All, thx for the help.
Region North America 2.4G Channel Auto ( 3 ) 2.4G Mode Up to 400 Mbps 5G Channel 36+40+44+48(P) 5G Mode Up to 866.7 Mbps
What firmware did you end up with?
