shadybiz11
Apr 03, 2020Aspirant
Orbi RBR50 & 3 Satellites, moving to house with Cox Panoramic
Ihve had my Orbi system for a few years. Using Router and 3 satellites to cover my acreage. I'm moving into town, where my only choice for high speed internet is Cox Panoramic Wifi Gateway. Cox sa...
Apr 07, 2020Guru - Experienced User
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
shadybiz11 wrote:Ihve had my Orbi system for a few years. Using Router and 3 satellites to cover my acreage. I'm moving into town, where my only choice for high speed internet is Cox Panoramic Wifi Gateway. Cox says that I have to rent their internet Modem Router unless I have my own Cox approived DOCSIS 3.0+ cable internet modem. Does this mean that I can't use my orbi system with Cox Internet?
