DesertBruin's avatar
Mar 05, 2021
ORBI RBR50 / CM1000v2 Router Connection Issues
Having frequent issues with the above combination dropping connection from ISP, 6-7 times per day. Router shows connection, Orbi goes magenta ring.   ISP (Mediacom) has confirmed no line issues, an...
  • DesertBruin's avatar
    DesertBruin
    Mar 05, 2021
    Not on any network devices. Orbi updated firmware  a couple days ago, but this problem was already ongoing.
    I'll try the factory reset and see if that makes things more stable. Thanks!
