axom
Aug 22, 2020Aspirant
Orbi RBR50 / RBK53 internet speed dropping every few days
My RBR50 router drops from 120Mbps download speeds to 10Mbps every few days and I have to reset the router to get it back to 120Mbps. I've read some articles on similar problems but haven't seen a re...
- Aug 27, 2020
Thanks for the reply guys. I think I may have figured it out. 4 days ago I decided to look at the settings in my Arris modem. The link aggregation setting was set to on. I turned it off and my speed hasn't dropped since. I'm hoping that was the issue and that it helps anyone else having the same issue with similar equipment.
axom
Aug 27, 2020Aspirant
Aug 27, 2020Guru - Experienced User
Glad you found the problem.
Enjoy. :smileywink:
