KFRALICK
Apr 19, 2019Aspirant
Orbi RBR50 + RBRS50 firmware stuck on V2.1.4.16_1.0.0.11
Cannot update firmware
KFRALICK
Apr 22, 2019Aspirant
Its not working either way. when I try to update manually it keeps telling me that the file is incorrect?
Apr 22, 2019Guru - Experienced User
And you did unpack the .zip file to reveal the sub files correct? And you tried to apply v210 and v212 first to the RBR?
If so, I would make contact with NG support:
- aykornbSep 03, 2019Aspirant
have same issue... i think it's because it's a verizon branded sattelite
- CrimpOnSep 03, 2019Guru - Experienced User
Oh, s**t. You are screwed. Service providers change the firmware to allow only them to perform updates. There is a thread on the forum about one Verizon customer who went so far as to try to force a firmware update using the Trivial File Transport Protocol (TFTP) which is built into the routers. As I recall, this BRICKED the Orbi.
If the Orbi is not working in some manner, maybe you can escalate the issue to "Level II" (or whatever) and get a better resolution.
- FURRYe38Sep 04, 2019Guru - Experienced User
IF this is a Verizon branded system or unit, then upgrading with NG stock FW will not work. You have to go back to Verizon to see if they have FW that you can update on there branded systems. NG stock FW will not work in this case.
aykornb wrote:have same issue... i think it's because it's a verizon branded sattelite
