bry1202
Jan 23, 2021Aspirant
Orbi RBR50 > RBS50 > Ethernet Switch
Hello, I have a 2 node RBR50 > RBS50 satelite mesh network setup in the house. Going to be adding ethernet to bedrooms this week and ethernet backhaul to RBS50. I have been searching through th...
GMoGoody8
Jan 23, 2021Luminary
I was following a bunch of threads on here too over the summer and saw the same reports when I planning my new home.
I just moved last week and can confirm Ethernet Backhaul will work with Green Ethernet(802.3AZ) with the newer FWs.
Here is my setup.
Modem—> RBR50–>home run cat 6 to patch panel—> Netgear GS108 unmanaged switch —> home run cat 6 to RBS50 —> Netgear GS 108 in entertainment center.
Here is my setup.
bry1202
Jan 24, 2021Aspirant
Thank you for the update! I found a Dlink 24 port switch with a toggle to disable EEE (green ethernet) so I purchased that. It was about double the price of the other switch I was looking at but this one comes with a rack kit so I guess I will keep this one. Thanks again :)
- FURRYe38Jan 24, 2021Guru - Experienced User
- bry1202Jan 24, 2021Aspirant
Yeah obviously I have read that article.. I have also read the countless posts of people having issues. I actually chatted with Orbi/Negear support and they confirmed you cannot have a switch with EEE in between the RBR/RBS.
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems. Tried and tested.
