bry1202
Jan 23, 2021Aspirant
Orbi RBR50 > RBS50 > Ethernet Switch
Hello, I have a 2 node RBR50 > RBS50 satelite mesh network setup in the house. Going to be adding ethernet to bedrooms this week and ethernet backhaul to RBS50. I have been searching through th...
bry1202
Jan 24, 2021Aspirant
Thank you for the update! I found a Dlink 24 port switch with a toggle to disable EEE (green ethernet) so I purchased that. It was about double the price of the other switch I was looking at but this one comes with a rack kit so I guess I will keep this one. Thanks again :)
Jan 24, 2021Guru - Experienced User
- bry1202Jan 24, 2021Aspirant
Yeah obviously I have read that article.. I have also read the countless posts of people having issues. I actually chatted with Orbi/Negear support and they confirmed you cannot have a switch with EEE in between the RBR/RBS.
- FURRYe38Jan 24, 2021Guru - Experienced User
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems. Tried and tested.
- Giorgio82Apr 17, 2021AspirantLate to the party on this one it seems but I can’t find any answers.
I have an Orbi (2 piece) set up and just bought a GS108 switch. I have modem > RBR 50 > GS108 > Cat 6 running from 5 rooms. The WiFi stops working as soon as I plug the GS108 into the RBR 50 and nothing is connecting via Ethernet either. Any ideas?
