Raemey
Jan 03, 2019Aspirant
Orbi RBR50 + satellite disconnects regularly
I have the RBR50 near the incoming access for the internet line into the house. It is high up on the top of a cabinet. I have the satellite about 50 feet away. When the two are connected I am gett...
- Jan 03, 2019
Raemey wrote:
It is possible to have the RBS50 connected by ethernet, but will have to have my tech person do it. Too much of a challenge for a 71 year old lady with medical issues. Thanks for the suggestion. If that doesn't work I will order another satellite. Is the RBS50 still a viable choice? Or has it been replaced by another model? And if so, can they be melded together to work?
Yes RBS50 is available and is a good option, another option for this purpose s the RBW30 (plug in Satellite) if you don't need the 1.7 Gbps backhaul and can be satisfied with the 867 Mbps backhaul.
Good luck!
Raemey
ekhalil
Jan 03, 2019Master
Good luck!
