Soyuz
Nov 14, 2020Aspirant
Orbi RBR50 + Satellite wifi dropouts, wired/wireless setup
Hi all! I have a RBK50 system (RBR50 router + RBS50 satellite) which is giving me lots of trouble with the wifi connection. Let me explain my setup please: Internet comes from the ISP router in b...
Nov 14, 2020Guru - Experienced User
"On the other hand, the RBS-50 satellite is wirelessly linked to the RBR50, for expanding the wireless coverage (it's around 13 feet away from the RBR50, in clear sight)." 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Soyuz
Hello, thank you!
Firmware version: 2.5.2.4
ISP modem model: Mitrastar GPT-2541 GNAC
WIFI neighbours: 3
About distance between satellite and router: never imagined that "being too close" could be a problem. I thought the opposite would be.
- FURRYe38Nov 14, 2020Guru - Experienced User
Distance between the RBR and RBS is important.
Also you might update to v40:
Others have posted that v4 isn't working well...Or downgrade to v16.
- SoyuzNov 15, 2020Aspirant
Thank you for your answer!
- I've updated both router and satellite to 2.6.140
- I've moved my satellite upstairs (I live in a duplex), to the opposite side of the house (>30 feet), and now it's connected by ethernet to the TP-Link switch, so I have wired backhaul.
I'll wait for a day to see how it performs, but I'm afraid that now I have some dead zones downstairs that I did not have before (maybe adding a RBS20 satellite downstairs would help? But it would be a bit less that 30 feet to the router, with some walls inbetween though...).
BTW, my Advanced Wireless settings are:20/40 MHz Coexistence enabled
WMM enabled for 2.4 and 5GHz
Daisy chain topology disabled
Implicit Beamforming enabled
MU-MIMO enabled
Fast roaming disabled
...bad experience with the new Satellite placement (annoying dead zones). I've moved it to another point (still upstairs) and now everything seems fine (without wired backhaul though). Let's see how this performs in terms of wifi dropouts...
