Paiatz
Jun 28, 2018Guide
Orbi RBR50 + satellite
Hello all,
i´m using RBR50 system with 2 sattelites. I have this question: Is there a possibility to check if i´m connected over a sattelite or just connected to base station ?
thx in adv...
- Jun 28, 2018The Orbi app should also show it. Click on a satellite and you'll see the attached devices tab
Jun 28, 2018Guru - Experienced User
You can log into the router and or the satellites web pages to check whats connected at each device.
