Gabe501
Oct 12, 2018Aspirant
Orbi RBR50 + satellite
My Orbi router has not been working for a couple of days now. I have had it for about 10 months now, and all of the sudden It doesn’t link up with my modem, i try the regular setup and the power butto...
Retired_Member
Oct 12, 2018
Gabe501 wrote:
My Orbi router has not been working for a couple of days now. I have had it for about 10 months now, and all of the sudden It doesn’t link up with my modem, i try the regular setup and the power button flashes green then flashes red then back to green. I tried holding the restart button on it to restore it to facory settings but that did not work the power light stayed green and didn’t turn orange. Then i tried the 30-30-30 that i read about, that brought up the link light on my modem but the power button just stayed a constant red. Any other way to try and fix it or am I going to have to buy a new one
Are you sure it's the Orbi? Check your modem by running the modem straight to your PC.
Gabe501
im sure i hooked up my old router to my modem and it works
