Gabe501
Oct 12, 2018Aspirant
Orbi RBR50 + satellite
My Orbi router has not been working for a couple of days now. I have had it for about 10 months now, and all of the sudden It doesn’t link up with my modem, i try the regular setup and the power butto...
Gabe501
i tried factory setting it with and with out a computer conected and the power light flashes red and not amber
Oct 13, 2018Guru - Experienced User
Look at the top of the orbi for the LED light. not the back of the LED in back.
- Gabe501Oct 18, 2018Aspirant
i held the reset for over 3 min and nothing changed only the back light
- FURRYe38Oct 18, 2018Guru - Experienced User
The top LED light did nothing?
Its already flashing white, just will not connect with my modem but my other two previous routers will. It also will not factory reset. The router has been working just fine for the past 11 months but all of the sudden pooped out and will not connect to my modem
