mercorelli's avatar
Sep 29, 2023
Orbi RBR50 | Trying to connect Gosund Smart Plugs
I've been using our Orbi RBR50  router and Gosund smart plugs for a couple years. Recently, we reset the password on the router and now need to reconnect all the smart plugs, however, the smart plugs...
  • mercorelli's avatar
    mercorelli
    Oct 02, 2023
    I have the solution. I will post here and on the other related thread. Just a reminder the issue was that I reset the pw on my wifi router and needed to re-sync all the Gosund smart plugs.
    The Gosund smart plugs can be sync'd/paired via a wifi signal that is broadcast from the plug itself. Instead of putting the plug in a "quick blink" mode, you long-press the button again to put it in a "slow blink" mode. Once in slow-blink mode, you will see a new network listed in your wifi connection list called "SmartLifexxxx" which you can select, connect to, and pair the device using an alternate setup procedure.
    Here are the steps:
    • Open the Gosund app
    • Go into each device, click the edit/setup pencil icon in the top-right of the screen
    • At the bottom, select "Remove Device", and then select the option to "wipe data" - repeat this process for all plugs that need to be reset
    • Back at the main screen, press the "+" button to add a new device
    • Select the socket/plug option
    • Enter your wifi name and pw
    • On the "Reset your device" screen, press "EZ Mode" in the top right, which will display a quick-pick menu
    • Select "AP Mode" from the menu
    • Plug the device in and confirm it is in 'slow blink' mode and, if not, long-press the button until you get a slow blink
    • Select "Go to Connect" to bring you to your phone's wifi setting to select the "SmartLifexxxx" wifi connection
    • Return to the app to complete the device connection
    This process worked successfully on all eight of my Gosund plugs. I've attached the screenshots sent to me by Gosund when troubleshooting the issue with them.
    Hope this helps the next person that runs into this!
