jimbari
Dec 27, 2020Follower
Orbi RBR50- Unable to access newly loaded webpages or internet-related application without reloading
Sometimes, when I attempt to access a webpage, I get an error, and I have to reload the site in order to actually see the content on it. Moreover, this issue also occurs with all types of programs tha...
RavenQuill
Feb 13, 2021Aspirant
I have had this issue since purchasing the the Orbi in November 2020. I haven't been able to isolate any variables of when it happens. I'm assuming on a related note, smart devices often have to try again to connect upon waking - my TV was always immediately on the network with previous routers, but now takes 10-20 seconds to reconnect to the network when waking.
I primarily use Chrome for browsing, though in a quick test had it occur once or twice in the current build of Edge.
Orbi firmware: 3.2.16.6 (there is an update available to 3.2.16.22, but failed previously, rendered the router non-functional and I had to roll back)
Feb 13, 2021Guru - Experienced User
Do you have a Orbi AX system? If so,
Please visit and post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
RavenQuill wrote:I have had this issue since purchasing the the Orbi in November 2020. I haven't been able to isolate any variables of when it happens. I'm assuming on a related note, smart devices often have to try again to connect upon waking - my TV was always immediately on the network with previous routers, but now takes 10-20 seconds to reconnect to the network when waking.
