duncanbell3
Oct 10, 2022Guide
Orbi RBR50 & Virgin Media
Hi all I'm a bit perplexed if I'm honest and would appreciate any help. As it says in the title I have an RBR50 and Virgin Media. I have been limited to 100MBPS package but just upgraded to ...
- Oct 11, 2022
Right after all these software issues it was actually nothing of the sort!
Changed the ethernet cable to a CAT8 (which was still cheap) and it fixed the problem.
Wifi now flying at the correct speeds.Which actually begs the question, why do Netgear Orbi only supply low grade ethernet cables?
This should surely come as some sort of warning on all Orbi products.
Really frustrating but glad just £10 can resolve the problem.
Sorry for wasting all of your time but REALLY appreciate all the help.
duncanbell3
Oct 10, 2022Guide
Just as an update, if I link to the Virgin wifi then I do get massively high speeds over 300MBPS but the reason I have the Orbi because the Virgin range is rubbish!
