duncanbell3
Oct 10, 2022Guide
Orbi RBR50 & Virgin Media
Hi all I'm a bit perplexed if I'm honest and would appreciate any help. As it says in the title I have an RBR50 and Virgin Media. I have been limited to 100MBPS package but just upgraded to ...
- Oct 11, 2022
Right after all these software issues it was actually nothing of the sort!
Changed the ethernet cable to a CAT8 (which was still cheap) and it fixed the problem.
Wifi now flying at the correct speeds.Which actually begs the question, why do Netgear Orbi only supply low grade ethernet cables?
This should surely come as some sort of warning on all Orbi products.
Really frustrating but glad just £10 can resolve the problem.
Sorry for wasting all of your time but REALLY appreciate all the help.
CrimpOn
Oct 11, 2022Guru - Experienced User
This reference shows the Virgin Media Hub 3 as having 4 1GB Ethernet LAN ports:
http://en.techinfodepot.shoutwiki.com/wiki/Virgin_Media_Super_Hub_3
When the new cable arrives, please return to the forum and report what happened.
duncanbell3
Oct 11, 2022Guide
- FURRYe38Oct 11, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - CrimpOnOct 11, 2022Guru - Experienced User
Manufacturers package thousands of Ethernet patch cables with products (Round, Flat, Cat5e, Cat6... Cat-whatever) and very few customers appear to experience this issue. It was the 92MB/s that led to this discovery. If the Orbi had reported 102MB/s I would never question the cable.
